fans1c013969
Flight distance : 766791 ft
DJI Paladin Posted at 3-6 09:50
Hi. I am sorry for the trouble this has caused. With regard to this concern. Kindly please, refresh the firmware using the DJI Assistant 2. After this step, please calibrate the compass of the drone in a location with less interference then please calibrate the IMU on a flat surface to isolate the issue. When you are calibrating the remote controller did you noticed if the Yaw is responding when you are pushing the altitude stick ( mode 2 )? Please keep us posted for further assistance. Thank you.
Thanks everyone for the helpful advice!
I tried using DJI assistance 2, but I couldn't get it to work properly. Either way, using the updater through the DJI Go App, it's telling me that I have the latest firmware installed.
BUT, when I went to calibrate the controller, it did show Yaw movement on the stick when all I did was push straight up. Sometimes it was up to 50%, which now makes a lot of sense.
So I calibrated the controller and have yet to do a test flight, but it doesn't seem to 'add yaw' anymore when I'm calibrating.
By the way, what's the best way to calibrate the controller?
Hopefully when I do a test flight I won't have problems anymore. It's almost impossible to shoot video with it panning all the time.
Thanks again though! And I'll post again after I get it in the air. |
