fans8e299cb6
Flight distance : 5675820 ft
DJI Gamora Posted at 3-12 12:40
Hi, thank you for reaching out and we're sorry for the inconvenience. May I ask if you have the option to record before an 1920x1080 or since then you don't have this option? Also, can you please check under FPV option > Settings > Recording Settings > Then set it as 1080p/60 to see if the problem persist. Furthermore, please make sure that you have the updated firmware for the DJI FPV Air unit to avoid any possible issues. You may refer to the image below. Hope this helps. Thank you!
[view_image]
If camera is set to 4:3, the video is 1440x1080. If set to 16:9, it is 1920x1080.
Can you confirm this is how it is supposed to work? |
