AlansDronePics
Flight distance : 814751 ft
Guernsey
Try putting it back on the charger. If that shows a fault, then the battery needs to be replaced. Hopefully, it will be under warranty. If not, it is scrap.
If the charger shows no-fault, examine the connectors on battery and drone.
Was the firmware recently updated on drone & battery? I recently lost a good battery because of firmware failure in the battery. Mavic Pro. The clue was middle two lights only stayed on 1 minute, off for 1 second. I doubt that is your problem though.
