JJB*
Flight distance : 12225059 ft
Hi Dusty,
I cannot help yuo in the way that i know the solution to your P4P errors.
But in this flight the first error is a 'SpeedErrorLarge', wich means that the speed calculated by the drone is not equal to the actual GPS speed.
Follow up is often a YAW, Compass and IMU errors.
See my chart ; upper part you see difference XY speed (derived from X and Y speed component) and GPS speed.
At ID 370 no inputs made on the RC, so craft should be in a steady hover, but craft did moved away.
This seen in Move heading red line wich should not be there (750 left under to 850)
All you can do is calibrate IMU and Compass, as you did it already....looks a hardware fail in the system.
If this sequence of errors always start with a 'speed error' than the GPS part is suspected.
But just my 2-cents.
cheers
JJB |
