AlanHd
Flight distance : 797365 ft
DJI Stephen Posted at 3-14 11:29
Hello and good day MKosmo. Thank you for reaching out and for the inquiry. The Double Tap function of the DJI Osmo Pocket features the following. When in Photo, Video, or Slow Motion mode, double tap on the screen to enable ActiveTrack. FaceTrack is enables if a face is detected. When the camera is facing toward the user, FaceTrack is enables automatically. Press the Power/Function button or tap on the screen to exit ActiveTrack. In addition the ActiveTrack is disabled in FPV mode and Video mode with 4K 60fps resolution and when connected to DJI Mimo application, the touch screen turns off and cannot be used. Thank you.
I think you have the wrong end of the stick, the OP is talking about the function button which the manual has the following to say
Press and hold the Power/Function button for one second to power on/off.
In camera view, press the Power/Function button once to switch between Video and Photo mode (not available when using Pro settings on DJI Mimo). Press the button twice to recenter the gimbal and press the button three times to switch the camera between facing forward and backward (requires firmware version v1.2.0.20 or higher).
In the touch screen settings page, press the button once to go back to the previous menu. |
