AlansDronePics
Flight distance : 814751 ft
Guernsey
Link to Flight Logs and supporting videos https://1drv.ms/u/s!ArAx9oM6899Rgec7dYUMu4fz3YT5-g?e=M6UvJy
As others here know, I was not convinced that magnetic interference is a trigger for the GENUINE flyaways we hear about on the forum. It is my personal opinion that it is a hardware or software glitch. It is possible to detect these glitches with something bench-bound like a computer or similar. You can’t do this with a flying drone. Therefore, a glitch isn’t provable.
What is observable is the result of a drone (Mavic Pro) that has been deliberately flown from an unsafe surface. The logic being that the magnetic interference will cause a measurable result in the log file. It should cause the drone to malfunction in some way that can sensibly be attributed to the interference. If no error shows up, even under extreme conditions, then it casts doubt on Magnetic interference being the predictable cause of a flyaway.
I took certain precautions to limit the risk to people or buildings, should the flyaway happen. The reported behaviour of an uncontrollable drone is that it flies off at a constant altitude. I picked a spot where a very high hill screens the populous so the drone would crash into it or fly off over the sea.
I considered the loss of the drone carefully. Although I was not convinced Mag Inf was a drone killer, I accepted that it was a serious risk and goodbye Mavic was acceptable.
The manual and common sense warn drone users NOT to fly if the drone warns of magnetic interference.
So, don’t do it!
I tried using a normal compass to detect magnetic force, but it was insensitive. Instead, I used the built-in App on a Samsung S9+.
A WW2 reinforced concrete bunker is akin to a large car park or flat roof building. There is a strong magnetic field produced by the reinforcement and solid steel beams but if it has been built for at least a year or so, the steel loses its random field and takes on the earth’s alignment within about 15 degrees max. Ships are known for this also. A modern car, like mine, can have different polarity in the width of a door panel and be random. The deviation there is as much as 180 degrees. The same for the roof and bonnet or hood and be very strong.
I decided to use the readings from the drone to determine the most powerful magnetic field. It is the drone that is affected, so there can’t be any disagreement there. I also looked for a yellow warning triangle on the GO4 App screen, but there wasn’t one. I placed the drone pointing (magnetic) east on the car bonnet because the north pole on the steel was (Magnetic) west. It was suggested by a wise member here, that if the magnetic field at the TO point coincided with magnetic north, the drone would warn of interference, but still be properly aligned. I thought this was sound reasoning.
During the test flight, I landed once facing magnetic north on a bunker with a 12 deviation from the north, then took off again. It will be interesting to see the flight log analysis at this point.
Readers should also know that I use old firmware that predates the NFZ system. It is a modified version from No Limit Drones, the only differences are user-adjustable parameters, beyond DJIs settings. I use all those DJI standard settings. I decided to use the old firmware because Mavic Pro s hit a bad patch with broken firmware. It was the only time I had a near flyaway and at that time, there was no way to revert to earlier firmware. Current firmware is 1.03.07 and has been stable in all respects for 18 months flying.
I used a fixed video camera to record the flights, as much as it could. There will always be someone who thinks it’s a scam. The drone was recording as well. I confess to a mistake. I accidentally set focus to close up, so everything is blurred as well as low resolution. Sorry.
Having taken off from the car bonnet and not wishing to lose the drone, I ran through simple checks to verify the drone was stable at this point. I was aware that flyaways usually happen later. I circled, increasing the radius and also flew very low over the bunkers to upset the compass system. I flew up (altitude) to 121 metres and generally in line of sight. All this I do normally anyway when I take photos and video.
We now await comment from those reviewing the flight logs. I am most grateful to them for their valuable time.
