Hi Robert, were you flying indoors? When the GPS signal is weak and the Downward Vision System is activated, the height will be restricted to 5m, please fly in open areas with strong GPS signal and make sure the aircraft Status Indicator blinks green. The APP will also show flight status on the top left side.
MBrobo Posted at 3-22 05:47
Dear DJI Mindy,
thank you for your reply ... please see the picture from the air ... can't fly higher than 5 m / 16 ft [view_image]
Apparently this was the second take off since power on ... that's why the log starts at 192sec. But as pointed out earlier you need to have GPS sat lock to get rid of this height restriction. Your AC didn't have any satellite locks & the navHealth were 0. The VPS sensors were active & reported height parallel to the barometric sensor. You didn't have any HP recorded.
See to that you have at least 8 sats locked & the HP recorded before take off ... then this restriction will be deactivated.
Dear DJI Mindy,
You are asking for trouble firing up and taking off from that concrete parking lot. That's how people lose their aircraft due to compass errors.
Dear slup & Geebax,
WoW thank you for all reply. but I don't know what you talkin bout... my drone dji mavic air ... fly normal until last days ... but now it is like
it is can't fly higher than 5 m / 16 ft and I don´t know what hapened ...
Tham I decidet to go DJI forum ask for help... I see here are a lot very clever DJI users... but I am not clever like you are... please can you explain me step by step how can I cancel the 5 m / 16 ft fly restriction or do I have to send my dji mavic air to DJI service to fix this 5 m / 16 ft fly restriction.
Thank you for help
Best regards
Robert
MBrobo Posted at 3-22 16:28
Dear slup & Geebax,
Aloha Robert,
Try bringing a plastic or wood small table with you to the launch spot. That will lift the Mavic Air from the concrete with its iron rebar. You may also be asked to do a compass calibration by the flight program.
As said by others, you need enough satellites and good reception of the signals.
In your log both are ZERO all the time, so mayby it is a hardware fail of the GPS chip.
If you still cannot receive signals (before no problem as you said) , than contact DJI for a repair.
Dear Folks,
thank you for all replies, I will send my drone dji mavic air to the DJI EU center to fix the problem, I let you know ... what they fix ...
Best regards to all
Robert
