DJI Spark battery won't charge.
46921 35 2020-3-21
Serv27
The battery for my DJI spark will not charge. When I press the buttons there are no lights. If I attach the battery to the Spark and charge via USB after pressing the button I get 6 flashes from the first light followed by 4 flashes from lights one and two respectively but still no power and no flashes after the Spark is removed from the charger.
2020-3-21
lashmett75aol.com
I have 2 batteries doing the same thing..
Anyone with knowledge on how to remidy the issues would be greatly appreciated.
2020-3-21
DJI Thor
Flight distance : 13602 ft
Sorry for the issue, the battery may need to be replaced. When did you purchase the drone/battery? If it is under the warranty period, you may contact our support for further assistance. You can contact us at http://www.dji.com/support
2020-3-22
Serv27
DJI Thor Posted at 3-22 19:00
THE BATTERIES ARE ALMOST 2 YEARS OLD BUT WERE NEVER USED IN FLIGHT AND ONLY TURNED THE UNIT ON ONCE.
2020-3-23
DJI Thor
Serv27 Posted at 3-23 12:57
I am very sorry about the case. Could you please provide the serial number of the batteries for a further check? At the same time, please try to keep the battery charging for about 2 hours.
Besides, to maintain battery health, we suggest storing the battery at 40~65% power if you are going to have a long time not using it. Totally discharge and charge the battery at least once every 3 months. We have battery care guides here for your reference, too.
https://store.dji.com/guides/bat ... 0flqPmAznOxLk0_LX5Q
2020-3-24
NRRTRAINS 85
here is the SPARK BATTERY DISPLAY . i hope it helps you .
2020-3-25
Serv27
DJI Thor Posted at 3-24 19:03
0C0AE78B3202FJ & 0C0AECPB3301X6
2020-4-1
DJI Thor
Serv27 Posted at 4-1 12:09
Thank you for getting back, the batteries are beyond the warranty period indeed, you may replace the batteries. Sorry again for the situation. To maintain battery health, please kindly refer to my reply on 6#.
2020-4-2
djiuser_GQywkXonliaT
I have the same problem. All of a sudden neither of my two batteries will charge via USB. When I plug it in, nothing happens, no lights.. Have tried with different cables and have tried leaving it overnight, but still nothing happens? It can't be the battery cause it's both of them having the same issue?
2020-6-26
Av8or1ab
Flight distance : 4478 ft
I am having the same issue with 2 batteries. This is absolutely unacceptable. I created a ticket with support and got the same run around of telling me to buy a new battery due to their faulty design and hardware. I plan on selling my drone as soon as I can and never buying anything DJI again. What a waste of everyone's time.
Here is the link to my video: https://youtu.be/kiSdAC9wyHs
2020-7-28
Av8or1ab
DJI doesn't care about their customers. Attached is my support thread asking for remediation and being told that they won't help.
2020-7-31
Blushift1
I don't know if this will help anyone, but here is my experience today with 5 batteries that have been dormant for 10 months.  I have a DJI three battery charging hub.  I went to charge the first three, of my five, and only the first battery started showing signs of charging.  The other two had no lights when connected to the charger.  When i pressed their buttons, one light would flash for a short while, but still not able to charge.  I then placed one of these batteries into the Spark and turned on the Spark with the normal double press.  The Spark started up and I let it cycle through for a normal startup.  I then turned off the Spark with the normal double button press and removed the battery.  It now is charging, as normal, in the battery charging hub.  The others that seemed dead are charging as well.
2020-8-13
TheThing
I'm having the same exact issue. It's unfortunate since I've only used my $500 drone one time for a short flight and have only just gotten to a location where I have adequate room to play with it. Not willing to pay 10-20% of the cost of the drone just for a new battery. It's a nice looking paperweight at least. It goes without saying I will never be buying from DJI again.
2020-8-26
Shadowblues
Same issue here. I opened the battery and checked the internal power of the 3 single cells. They were low, but acceptable. So I charged and decharged them a few times. The cells are working fine and they have nearly the same capacity. But the battery does not work. If I put it in the drone and attach it to the charger, I have two different light signals: Battery 1: left two leds flashing 4 times, then break, then repeat. Battery 2: left three leds flashing 3 times, then break, then repeat.
What I really do not understand is, that DJI is not giving out the meaning of those led codes.
I already bought two new batteries but as long as DJI is behaving that way, this was my last drone from DJI. No chance to get any more money from me.
What I will do next is to print an adapter which fits to the internal contacts of the battery and let an external charger rebalance the batteries.
2020-8-26
Wolferl
Flight distance : 23793 ft
Av8or1ab Posted at 7-28 09:33
Hi Av8orlab,
Having seen your YT video, it could be the power supply you used. It needs to supply at least 2 amps (better 3 amps) to be accepted. Your PS seems to be right at the border, it shuts down as soon as the full current is needed.
Can you try another power supply?
Cheers,
Wolferl
2020-8-27
djiuser_TKIKp3zYqMhm
I'm having the exact same problem with one of my DJI Spark batteries. Pretty sad the way this company has been treating customers lately. I have and many many others as well have a problem with their air units saying SD card slow all the sudden. They don't seem to care. I will never buy anything from this company ever again. Every chance I get I will let people know they are all about taking your money and that's about it. I recommend people looking into AUTEL drones from now on.
2021-3-23
lsrn
Flight distance : 16 ft
Using this drone occasionally. Same exact problem here, this is beyond frustrating.
I own another drone and a ronin s, had random issues and DJI customer service was quite disappointing every time.
You are making drones that grandmas can fly, but require an exceptional care of these batteries. This looks more like planned obsolescence by design to me.
This was the last straw, I am done with this brand.
2021-6-23
djiuser_p5MC0JsXWueI
Belgium
Shadowblues Posted at 2020-8-26 22:20
Hey, shadow, late reply, but did you get lucky with the external balancing ? I charged the cells seperate up to 3 leds, but still nothing
Grt Pat
2021-7-11
0Stephan
Flight distance : 451631 ft
Av8or1ab Posted at 2020-7-31 12:35
[view_image]
It appears to me that between batteries and drones, DJI can do something if a drone falls out of the sky, because they can get the flight log. With batteries, they have no log to use, and therefore can only assume that you either did or did not store them properly.
When I got my Spark last summer, the batteries were over 1 year old, but never used. After a full charge through the DJI 3 battery charger, they came back from their sleep and worked as they should have. Over this winter, I discharged them to 50-75%, and when I charged them up later in the spring, they worked fine.
Try following Blushift1's post #15 to see if it would help you out
2021-7-27
Jakab Gipsz
Hungary
A great many of the complainants use batteries completely badly. DJI does not stress the importance of battery management enough.
1. the LiPO battery will fail if it is completely discharged and not charged as soon as possible (within 20 minutes)
2. the LiPO battery will be damaged if left fully charged for an extended period of time
3. it should be stored at 50-55% charge for longer periods (winter)
and recharge after very long storage (6 months) if necessary.
4. do not discharge below 20% charge during flight if not necessary. The best lifetime is possible using between 80%-20%, but 80% would give little flight time.
5. Only charge to 100% before the flight and discharge as soon as possible (point 2). If you are not going to fly it that day, you should use 50-55%. (point 3)
If you follow these instructions, you will have a good battery for a long time.
I read in many posts that you didn't use it, then took it out and it didn't work. This is the most common mistake that destroys cells: deep discharge!
2021-7-31
MikaelBe
Flight distance : 108665 ft
Sweden
Jakab Gipsz Posted at 7-31 09:40
Hm, according to the manual, the battery should discharge by itself. After 10 days of idle, it will discharge to below 70%, and it takes two days to reach 65 %. It does not mention how far it will go. I have started to charge the batteries now and then, just to try to avoid any risk of depleted batteries. They are three years old and still work. I agree that LiPo batteries should be stored at about 3.8V per cell, which should roughly be about 50% capacity, I have some other LiPo batteries which are almost ten years old which still works OK.
If you leave a "ordinary" LiPo with no fancy electronics at 50% it can be stored "forever", but I guess these Intelligent Batteries always draw some current?
2021-8-16
Jakab Gipsz
Hungary
MikaelBe Posted at 8-16 23:53
1. Yes, the electronics protect the battery, so after 10 days it will discharge to about 50%. But that doesn't mean that 10 days is not a problem. Every day you store the battery at 100% charge, it slowly damages the battery. So I never wait for the protection to drain it. If one of my batteries has not been flown out (I leave at least 20% in it), I will drain it to 55-50% on return home by hovering (this drains the sample faster than flying).
I recharge immediately before use, so that it lasts as short a time as possible at 100% charge. For example: I charge it in the evening if I want to fly it the next day.
2. The smart electronics disconnect themselves when hibernating to stop draining the battery. The Parrot Anafi's battery cannot be switched on even after 10 days, nothing happens even if you press the button. It can only be revived by charging via the USB-C connector on the battery.
2021-8-19
Laugsb1
I apologize if this is the wrong thread for this, but it is one of the few remaining active ones for Spark.  I have 3 batteries from my crashed Spark that someone is welcome to have for just the shipping charges from MD, USA (or we can meet within 30 or so miles).  I am also willing to give away the remote and a 3rd party charger that can charge 4 batteries and the remote at the same time.
2021-8-19
MikaelBe
Sweden
Jakab Gipsz Posted at 8-19 07:53
I agree completely to your method of discharging batteries to storage level (about 50%). I do use other "plain" LiPo batteries for planes, helicopters and if I charge the batteries for some flying and for some reason is not able to go out and fly I have a specific discharger to discharge them to storage level.
I am still a little suspicious about the DJI batteries, but maybe people have discharged them too much when flying, so when they come back after a year or so, the batteries are dead and can't be revived.  LiPo does not discharge by itself the same way as NiMH, but some self discharge will probably occur. It is good to check up on the batteries now and then (if you can remember it ). When I fly my planes and helicopters I will only fly until about storage level, which I know by experience what time it makes roughly. It is maybe a bit short, but then I don't have to recharge them at home afterwards.
2021-8-21
Spiinies
Laugsb1@gmail.com Posted at 8-19 13:03
Not sure if you still have the items mentioned, however, I am definitely interested in your offer.
2021-12-17
Gerry Condez
Got 3 extra batteries for our Spark for backup a year and a half ago charged and never been used.  They all won’t charge now.
2021-12-28
djiuser_yrjAhxXkI0tj
Laugsb1@gmail.com Posted at 2021-8-19 13:03
Do you still have the dji spark batteries and other parts? If so email me
2022-1-6
djiuser_6aSApwgMUEE9
New Zealand
Having read this thread, I don't think anyone can help me, but I'll try. I recently was given a Spark drone from a company going out of business. As far as I can find out, it was probably bought in 2017. It would not have been used much, if at all. I don't even know if it was ever activated.  It came in the box but the charger and usb cable were missing. I've tried charging the battery with various chargers and cables I have with no success. Sometimes when I press the button I get 1 flashing green light followed by two green lights flashing in sequence.
I assume this battery is dead?
2022-2-1
Prathmesh Tiwar
India
My Spark battery suddenly drops down to 0% while flying despite being fully charged. Any idea, what the problem could be?
2022-5-21
fans5b509fa9
Apparently these batteries are a real piece of junk. I must have used my spark about 5 or 6 times. I kept it for a while and today I went to recharge the batteries to use it again. The two dead. They stay connected to the charger for hours and only the first two LEDs flash 4 times and the cycle restarts. Not charge. The Internet is full of people complaining about these batteries, and there is even a market for the recovery and sale of alternative batteries. So expensive and so ordinary. Too bad
2022-7-24
djiuser_b6SzgiDklmhM
Hello,
I have the same problem as everyone here. I bought my drone three years ago and only used it three to four times and put it back in its box inside my house in a good environment without humidity and I don't have not retouched until today. I have 5 batteries and only one came back to life. I tried all the stuff I could find on the net and nothing. I realize by reading you and by reading the answers to your questions that I will surely have to buy other batteries. I find it really unfortunate on the part of DJI to have so many people who have the same problem and which seems really not normal to me that we have to reinvest in new batteries which, on my side, still smell like new. you need to do a few things for your customers. I admit that I'm not the one who used it the most for personal reasons, but I wanted to enjoy it during my vacation and here I am with a brand new drone that I can't even use.
a very disappointed customer ☹️
2022-8-2
djiuser_xn7PVz7mu4aX
Flight distance : 466 ft
Had the same problem, after using the batteries only a couple of times, I left them for many months and tried to recharge them and couldn't..... Had to buy new ones
2022-8-24
faithley
Flight distance : 116873 ft
South Africa
Blushift1 Posted at 2020-8-13 10:57
I had a similar incident where the spark battery also wouldn't charge in the 3 bay charging hub. so I placed it in the spark turned it on and plugged in the USB cable to the drone and charged it and it showed it was charging. I turned off the drone and plugged it back into the 3 bay charger and it charged. i regularly check and charge my batteries because i dont have money to buy new ones or even a new drone
2022-10-31
Wolferl
Austria
faithley Posted at 10-31 14:12
I had a similar problem. In preparation for a flight I had all 3 batteries and the R/C charged up at the charging station the evening before, and all looked fine.
When I went to fly, I noticed one of the batteries did not turn on.
I thought, oh sh*t, now it got me too...new Spark batteries are unobtanium now.
I then put that battery in the Spark and connected it to a 2 amp capable wall wart, and that battery came to life right away!
2022-11-1
lmx1111
I've been researching batteries recently and found out about unit pack power they have the [url]unitpackpower US site [https://unitpackpower.netl]and the [url]unitpackpower EU[https://unitpackpower.eul] site. I live in the US now, but I need to go to France next week, which website do you recommend me to buy from? How do you feel about their batteries?
2022-11-4
djiuser_FHHXiNqyPZFv
Still have them?
4-5 06:06
