Expregiat42
Singapore
I don’t think there is an option for applying processing to an incoming video, as there would with a hardware interface. This is what you get.
What you wanna do here is set the channel volume low when you are recording. Here you want the signal level to -18db for mixing. Avoid signal level near 0db. This should fix it.
I also faced the same issue while I was using Garageband on my Mac, however, on shifting to windows, I am unable to find a better alternative. Do you know any way around it?
