m80116
Flight distance : 3264131 ft
To be honest I don't know what most of you seem to be raging about.
My claims are easily verifiable by anyone using the simple flight reader online. While I see printouts and many other data that match up with the flight log, FRAP, i.e. the only free offline data analysis resource I have access to is not completely congruent with such data.
- With FRAP using the .txt log (the only one I can read) there's no indication of compass interference.
- The online data viewer should display much of what FRAP sees but timecodes are in disagreement, but that is recurring problem.
- What I see that FRAP doesn't show, and I don't get if there's some timing problem in FRAPs or actually some other data is displayed is that MM is tilted between 15 and 20° of roll pretty much the entire carry-away flight length (unti it tumbles down).
Everybody can check on https://www.phantomhelp.com/LogViewer/JNCMGGK8EY5CE64Z0VTQ/ and verify (even with a simple Protractor against the screen, unless is in reverse) that the bubble indicator shows that MM was actively countering a wind because at that point the GPS signal was good and strong, and was tilted between 15° to 20° TOWARDS the homepoint. That's not what happens when you have GPS position mismatch or COMPASS/YAW disagreements, where the AC actively fly in a different direction... he was fighting HARD to keep the position it was coming from!
What I see on the printouts I can't have access to is something that could very well be perfectly normal, as I don't even see a point of delta variation between the YAW/Compass data, at last not that that spatial resolution.
Now, about the hit a tree theory: well... I don't know, it seems a bit unrealistic to me. I think we agree at that point the drone started tumbling down. For what I've seen from Google Street View pictures trees in the area seem to be around 15 to 20 meters or 65 feet tall, which should suggest it was capsized by the wind, which was already so powerful to carry it away despite MM countering it with 20° tilt towards the homepoint.
Unfortuntely as I have no way to read IMU data directly I can't see if the instant tumbling of the MM is compatibile with a hit or a gust of wind.
Thanks Labroides for showing us again with your arrogance, rude manners and your unintuitive way of exposing things how not to perorarate a cause, you've surely won the TURKEY on that, actually being detrimental to the concepts you're trying to stand by. |
