btemtzzz
Flight distance : 5705 ft
I do have a battery pad , But the first drop was violent and caused my lipo to come out of its sling.... I have learned my lesson but its Incredibly annoying as Im a newbie I now have to land and then check my voltage and then sometimes I have about 50 seconds left and its very frustrating taking off again and then landing within 1 minute.
Here is the Kicker -
Everything Works in Betaflight EVEN when armed I can see Battery Voltage meter updating, I took the props off i went into the motors tab I selected Enable safety which allowed my quad to be armed WHILE betaflight plugged in. WHen armed EVerything works perfectly Still in betaflight, VOLTAGE, Current , Amps measuring in real-time on the fly . But In the goggles Battery voltage meter frozen does not update at all.
I initially thought its betaflight so I opened a betaflight issue, But they confirmed it has nothing to do with betaflight and I need to contact DJI.... Another Kicker? This is happening on 2 separate DJI Air Units Bought from different dealers Both built on 2 different frames with the same T-motor F7 HD stack with 55a 32bit 4in1 esc. It happens On the firmware that it came with out of the box 4.1.1 and I updated it to the latest 4.1.5 16/03/2020 Still the same issue. Both Air units are latest updates dji 1.00.1004 .
Here is my thread in betaflight [CLOSED] and the developer confirms it has nothing to do with the T-motor and betaflight as they are both reading without no issue and it has to do with DJI https://github.com/betaflight/betaflight/issues/9630
This is SO frustrating as i'm only a new flyer and i'm not experienced enough to know when to land appropriately which causes me to land way too early and not enjoying the entire flight.
Interesting you mentioned Buzzer I have Enabled the DSHOT buzzer which is on an aux switch and also beeps when remote is not connected, this is handy if i want to find my quad. I also have the Vi-fly buzzer but not installed where do i install this to make it beep when low battery warning?
