SPECTRUMWAVE
Hi everyone!
My Inspire 2 won't let me control the gimbal pan and tilt anymore. Everything worked fine and suddenly the ability to control the cameras movement got lost.
I've tried so many things, such as downgrading the firmware to several versions of the Inspire and the two cendence remotes, that i have...
I've also re-installed the latest firmware a few times and have reset different settings in the menu. I've restored the aircraft to its default via DJI Assistant 2 ... and it still doesn't work.
When starting automatic gimbal calibration, it starts the calibration program and gets stuck at 20 % – every time! The camera is then tilting up to the max. I have to restart the aircraft such as the DJI GO 4 App then, to be able to exit the stuck gimbal calibration program.
By the way, everything else works! Camera settings and focus can be controlled, only the gimbal contol doesn't work – even via the touchscreen gimbal control function, it won't move!
The gimbal motors seem to work fine also because the gimbal aligns itself to its standart position like it should (gimbal dance).
I am running on firmware version v01.01.0050 (cendence remote) and V01.02.0200 (aircraft) right now // not on the latest one due to some downgrade-testing... But like i said, latest versions are not helping out here...
[size=14.666666984558105px]SETUP: Inspire 2 with Zenmuse X7, 2 x Cendence Remote, 2 x CrystalSky Monitor // ProRes and Cinema DNG activated
If someone has an idea – please let me know. I go nuts with that problem, the Inspire is unusable with that.
Will even pay a reward for the solution! THANK YOU!
THIS IS SO ANNOYING! – DJI, WHATS GOING ON HERE?
