Why Autoland in this Flight?
1010 5 2020-3-27
stuka75
Flight distance : 85682 ft
Havent flown this unit for 8 months and did a LItchi waypoint flight. At the end, after I ordered rth I thought I was landing the drone manually, but it was rather an awkward but succefull landing. The attached is the flight record and I would appreciate some input so I can figure out what I did wrong. More specifically why it was in autolanding mode whcih may explain the awkward final touchdown.https://www.phantomhelp.com/LogViewer/SH7WOAGINS1MN0098PO1
Thanks
2020-3-27
WD9EON
Flight distance : 686886 ft
check your settings for low battery
2020-3-27
Pleomax
Flight distance : 835725 ft
When AC is in manual or auto RTH the AC will autoland after reaching Home Point unless the operator cancels either RTH or autoland.
2020-3-27
Mark The Droner
Flight distance : 2917 ft
If you have RTH set to fly home and land, it will fly home and land.  You can steer it down with the controller but you can't stop it from landing unless you cancel the RTH.  So your ability to steer it down might have misled you into thinking you had full control.
2020-3-27
Labroides
Flight distance : 9991457 ft
The autolanding started when the drone had returned to above the home point.
That's how it is programmed and what it does.
It would have landed smoothly, close to the launch point if you hadn't fought against it.
That's what caused the awkward touchdown.
You can cancel RTH and land for yourself or you can let it do what it's programmed to.
But fighting against the automated landing is never a good idea.
2020-3-27
stuka75
Thanks all. I thought I had cancelled rth, must must not have.
2020-4-21
