Mizzu
Flight distance : 431873 ft
Ice_2k Posted at 3-27 07:05
because in S-mode the drone is faster and therefore tilts more (30 degrees and actually it's the other way around, it's faster *because* it tilts more but you get the gist of it ), which makes it much more likely to exceed the physical range of the gimbal. The gimbal can go to about 110 degrees (0 being straigh forward and 90 directly down). If you're looking straight down and go full speed backwards in P-mode (20deg tilt), the gimbal will be able to compensate for it. If you do it in S (30 deg), it won't because 90 + 30 > 110
OK, sounds logic. But I didn't accelerate like a maniac. Or do you think that the angle gets that quick to the 30° in Sports-Mode that I can simply not do anything about it?
I didn't test it (visually) so far. |
