budnikasr
Actually when I go into airplane mode it shuts wifi and bluetooth off automatically, I would have to manually enable wifi. Look at the attached images. And no, it's a wide open field with no buildings or electrical interference at all around. My point was when I was on the current version of the Android app I get the messages with AP on or off. You're not the first post to suggest it. I had to revert back to the older version and even with the IOS as the slave with the latest version from DJI, it works perfect and I can go well beyond 1600ft, actually over 3000ft and it did not matter whether AP was on or off because when I first got my unit I was always flying with wifi turned on. You're saying "The second point is that even in airplane mode, wifi can still be on, and this is what blocks the second remote from receiving the video signal." Maybe in some situations that may be causing it for you, but I've tried your process and I am back to the old version. So there is more to this and would like DJI to comment or get it fixed. Before anyone makes a comment, yes, I used my iphone to capture the the attached images. Both devices shut everything off when switching to AP mode.
