Importing Fields as Shapefiles KML/KMZ
5196 4 2020-4-2
FC Mosquito
Can shapefiles be imported to the agras mg-1p? KML/KMZ or any other format?
Any info would be appreciated!
I'm hoping that our current KML files can be imported as fields.
This seems like such a simple thing, I thought DJI would make this an option.
2020-4-2
Currently, MG-1P doesn't support importing KML/KMZ file directly. It is recommended to import KML/KMZ file to DJI Terra, after finishing the flight mission, import the field files to the Remote Controller of the MG-1P.
2020-4-3
FC Mosquito
I just want to import EXISTING KML/KMZ files to the remote so they do not have to be flown or drawn before the treatment flights are executed.  Can this be done prior to  the flight mission using DJI Terra? I watched videos of DJI Terra and do not see this function.
2020-4-6
Agras NZ
Flight distance : 1843015 ft
New Zealand
It is an option for the P4 RTK, which uses the same controller as the MG1p????
2022-10-30
ro_walker
Brazil
I don't think you can.
2022-10-31
