jakboys
Flight distance : 280883 ft
Hey Jack,
Good Luck with Support.
While waiting, maybe this may help.
Since you just received it...
Prior to the battery update,
Updating the other firmware/software for the drone and remote,
should be performed and verified.
You will need the DJI Assistant 2 for Mavic first. (linked)
- DJI Assistant 2 for Mavic - to update drone, remote, and other required installs.
Update Drone, Remote, Databases, Registration, Batteries,
And whatever else, This should ultimately result in,
Upgrading the Mavic Mini, to default, stable firmware, version 1.06.
_______________________________________
To the brave*...
The official DJI Fly firmware APK (version -1.08) for Android.
- DJI Mavic Mini Firmware 1.08- APK (Android)
*The problem with this firmware (version 1.08), is phone compatibility, and the varying resulting issues.
To use this official DJI Fly- APK version 1.08 safely, perform a phone/tab compatibility verification.
Do some indoor testing, and low-altitude tests, prior to normal flight. (highly recommended)
