Geebax
congeetime Posted at 4-2 15:46
I would say about a minute after successfully calibrating which takes 2 or 3 times of calibrating before its successful. Also depends on location as well. I just flew it in my backyard. When I was in the middle of my backyard(all grass, nothing obstructing it), it couldnt pick up a GPS signals but when I moved closer to my house and on my deck, it picked up signal which I found kind of odd since my deck is slightly under my roof. Last time I used it, I was at a near by lake. Right beside the water with nothing obstructing it. It wouldn't pick up signal until I stepped back bout 2 or 3 metres.
Ahhh, I see, thanks for the info. I figured the signal strength would be about the same considering the mavic pro is a bit older than the mavic mini but now I know why my buddy was saying wifi drones are a bit questionable.
The first suggestion I would make is to stop 'calibrating' the aircraft every time, it is not necessary. The warning is badly worded, the real solution is to move the aircraft away from where you are launching from. Do not launch from a deck, there can be iron and steel in its construction.
With regard to the GPS, it depends a lot on the terrain where you are, if you are in a mountain area, it can take a while for the GPS to obtain a fix. Tall trees can also block the signal.
