djiguy001
DJI Mindy Posted at 4-4 01:02
Sorry for the difficulties on balancing, which lens are you using? It is recommended to remove all the accessories in the lens such as the filter, Lens hood and so on. Did you install the Riser Plate properly?
If there is no luck with the suggestion above, may we have a short video for further support?
Okay, thanks.
I think I figured it out on my own - I thought the camera had to be 'perfectly' balanced (i.e., not move) on one of the axis. It seems that the gimbal can compensate if it is not 'perfect' but at least 'pretty good'.
Thanks. |
