DenN
djiuser_feRCFGKa82KV Posted at 1-4 16:39
I just unboxed my mini, and I got a stuck propeller error. I turned the motors a little by hand and noticed a little resistance on the right front motor. It felt like a little too much litho grease in assembly, after a couple of turns it spins freely, and the code stopped and it flew fine for a couple of short indoor tests. But it still doesn’t spin as freely as the other motors. Is this just a “breaking in” issue that will improve? Or is it an indicator of a bigger problem? Sorry if I hijacked the thread. Thanks for any input!
Same here! Front left motor in my case, i noticed it when i first took off the stickers holding the props in the box for packaging and went on to check if all four motors rotate freely. The other 3 felt fine and turn easily but the front left one felt completely stuck. After trying a few seconds i managed to wiggle it free, now it rotates but still feels stickier than the rest, as if there's a bit of glue in it. Definitely not sand or any debris since it's brand new out of the box.
After finishing the unpacking and charging everything, i did manage to the mini turn on and spin without errors, so at least that's better. Didn't take off yet so don't know if it will be fine or that one will be warmer than the others.
Did you get any response from DJI? |
