Geebax
The setting for discharge time is stored in the aircraft. When a battery is inserted in the aircraft, the aircraft updates the discharge time and the value is sent to the battery. The default setting is 5 days, and that is perfecly adequate. The battery will discharge automatically when it is out of the aircraft, as in sitting in a carrying case. The countdown time starts after the battery was last used or was last in the aircraft. If you press the battery status button, it resets the countdown to zero again, so best to not press the button. If you have multiple batteries, place them in the aircraft to update the time.
