Osmo Mobile 3 and iPhone 11 Pro - Questions
836 2 2020-4-5
S18LOK
Flight distance : 389577 ft
Hi All,
I've done a search but can't seem to find the answer i'm looking for.
Really want to purchase the Osmo Mobile 3
Can anyone tell me if the Osmo Mobile 3 and iPhone 11 Pro (Not Max) is compatible?
I've heard that people have problems went using Wide angle lens with the part of the gimble showing and problems with Unbalanced issues.
Also can anyone tell me if it will work with a Apple Silicone case? as i don't want to be messing around, taking the case on and off.
Thanks!
2020-4-5
Thanks for your interest in Omso Mobile 3, it is compatible with iPhone 11 Pro. When using the ultra wide camera, the live view may be slightly blocked by the roll motor. In that case, move the mobile phone away from the motor slightly, it will be fine. Please check more details of the compatibility list: https://dl.djicdn.com/downloads/ ... ty_List_en_0116.pdf
The actual compatibility might be affected by accessories attached to your phone such as the case you mentioned, you could have a try with the case attached.
2020-4-5
Lucas775
Flight distance : 50642090 ft
Compatible, I've used my wifes phone which is the iPhone 11 pro max.  It works really awesome.
2020-5-2
