deathsquad
Flight distance : 6763835 ft
MontaukDrone Posted at 4-6 13:07
So, truthfully, it seemed to me like a (loss of) control problem the first time this happened, which is why I did not include that info. But as I stated, when it happened a second time, while I had the float on, while I was in Sport Mode it became apparent the Float was a common factor. In retrospect, I should have included that info in my first post.
So, regarding the use of the Float, I will say only this.... based on my research there have BEEN LOTS OF DRONES LOST IN WATER (regardless of the reason). My thought was, I AM GOING TO HAVE TO FLY OVER WATER... therefore I stand a chance of my drone going down in water. The LAST THING I WANT is my drone polluting some pond, or lake, or the ocean... sitting on the bottom, leaching out toxic chemicals from the battery... so I wanted to make EVERY EFFORT to prevent that from happening by being able to retrieve the drone if it were to ever go down in water.
I understand your reasoning but to me modifying the drone like that may actually increase your chance of the drone falling in the water. It's obviously causing issues in flight. It's also worth noting in sports mode the tilt the drone does is extreme and this may be what is causing it to flip. The drone angle is severe in sports mode to fly through the air faster. Try flying past yourself and watch the drone fly in normal P mode then in S mode.
I fly over a lot of water, here in Australia the beaches are the best places to shoot. But I would never even think to add flotation devices to the mini. If it lands in the ocean it's gone regardless. I have noticed at some locations if I get a little low, like under 5 metres, the drone wants to land or go down sometimes probably due to the sensors having issues detecting the water. I was shooting a boat dock and while adjusting the exposure I noticed the image moving down while I was tweaking it so quickly pressed up on the stick. You just have to be careful over water, especially at lower heights. I am very careful now not to hover too low to water. If you don't take risks and fly with a full battery in good conditions you shouldn't need to worry about losing your drone. Adding foam bits is a very bad idea in my opinion. |
