How to check if a Mavic 2 Pro is legit secondhand
1017 5 2020-4-7
dominicjames
Flight distance : 1445374 ft
Hi Guy's,
How can I check if a Mavic 2 Pro (EU) is legit?
The box it is being shown in has white internals rather than the normal black I've seen. I got him to sync the flight records and it show's no flights. I can see the serial number on the box 163CG8JR0A0W6B but only found this url (http://tools.retroroms.info) for checking, but it has no model info and a build date of August 2019.
What else can I do to check?
Thanks
Dominic
2020-4-7
hallmark007
Flight distance : 9827923 ft
Since I’ve been flying dji drones 5 years ago I have never come across a fake dji drone , you have checked tool rooms and serial number checks out that’s as much detail as you can get.
If you’re purchasing of someone you can check all it’s milage how many times battery has been charged as well as testing the craft itself.
If you’re buying sight unseen well it will be what it is.
2020-4-7
dominicjames
hallmark007 Posted at 4-7 03:46
Thanks, Captain, all valid points.
I've never seen a white internal packaging for a Mavic 2 Pro hence my nervousness.
Is there an easy way to check the battery info?
2020-4-7
hallmark007
dominicjames Posted at 4-7 04:01
Only way is to check on app used last.
2020-4-7
DJI Thor
Flight distance : 13602 ft
Hi Dominic, sent you PM regarding to your inquiry. Please check.
2020-4-8
DAFlys
It was posted on here a while ago that the newer M2P's have a white box insert.
2020-4-8
