Reddley
Flight distance : 699948 ft
Mark The Droner Posted at 4-8 02:34
I'm a little confused because you seem to be owning a P3S, but the controller you show in the gif is something different. Is it a P3A/P? I'll assume so since you posted in that forum I would open it up and find out why it's doing that.
Here is a youtube on how to open it. However, be advised there's a good chance the plastic stems inside which thread the metal screws will crack or break regardless of how careful you are removing the screws. It could be the plastic is already broken and a little piece of plastic is what is causing the problem. I replaced the stock screws with slightly longer screws so that they would reach in further and bite into that plastic. Good luck.
Hello, thanks for the reply, long ago my P3S crashed and a friend gave me his old P3P. I opened the remote and found a screw came lose on the joystick mount internally. |
