120ccpm
Flight distance : 1396755 ft
If I'm not mistaken, people have reported two type of unexpected altitude drops, with the MM:
1. Short drops, typically coming to a stop in S-Mode, fully recoverable (of course assuming you are not flying close to the ground). Theory is that sudden change in air pressure around the AC tricks the barometer, and the flight controller responds accordingly.
2. Full descents, unrecoverable, often linked to insufficient power error. Theory is that props have something to do with this, as some reportedly fixed the issue by replacing them. In my opinion, there is more to it as props don't go bad out of the blue, mid-flight. Maybe they (slowly) lose pitch and reach a point where the flight controller needs to max out the motors to keep the AC in the air, which triggers some sort of limp-mode, slowly bringing the AC down. Another option is that there is a true hardware problem, and the flight controller cannot keep the AC level without losing altitude.
To me, JJB's case seems more like a #2, no? The AC was basically stationary when it happened, and the drop was quite significant (10 meters). Moreover, the barometer appears to be perfectly working, as the height is correctly reported by DJI Fly. If this were a drop induced by false barometer readings, wouldn't we see inconsistencies in the height, as it's reported by the app (vs. actual)? |
