JohnDG
Flight distance : 1097270 ft
Belgium
Set your "default storage" to internal.
In some case you can see your logs. If you see them, it's the moment to synch with DJI. Then follow the next steps
Take out your SD card.
Install the latest firmware using "DJI Assistent 2 for mavic"
Restart your SC
now, you can put in your SD card (if any) and set your "default storage" where you want it
If this doesn't work, you better check with DJI for further instructions. |
