ronin sc pan axis
2432 3 2020-4-10
jodenis
have a probleme with my ronin sc pan axis. always re balance needed. everything fine manualy, i make the auto tune  but still not working
2020-4-10
Hi jodenis, sorry for the difficulties on the Pan axis balance, was your firmware updated to the latest version? What is the model of your camera? Please lift your Ronin-SC to the left or right (not forward or back) by 15° and then check whether the Pan axis will stay still, please refer to the tutorial video and try again, thanks.
2020-4-10
fans8f111678
I’m having the same problem with my gimbal and also my gimbal seems to drift
2020-4-20
dinbali
Indonesia
SOLUTION
Ronin SC Pan Axis unable to get ''Excellent'': While doing the balance test, I tilt the Gimbal over 25-30°, I then get ''Excellent''. If I immediately balance test again at 15° I get ''Re Balancing Required'', so it is some kind of bug. Just balance-test it at around 30° and it's good. Hope this helps anyone with the same problem. I have spent way too much time trying to solve it before I found out about this and I'm an expert in balancing a gimbal now xD
2021-9-21
