Hi Elby, sorry for the difficulties with the image transmission. Please follow the steps below for troubleshooting:
1. Please remove your Micro SD card to see if the issue persists.
2. Were you still able to control the gimbal?
3. Please reset the Camera Settings to see if it helps.
4. Then please double check if the cable in the gimbal is loose, you may try to re-insert it.
5. If there is still no luck, it is recommended to send in the drone for the evaluation. |
