What Tablet Works with Mavic Pro
877 10 2020-4-15
wllmsnamy
Flight distance : 5515 ft
Purchased a new Nextbook tablet to use with my mavic pro, made sure the table had Android version higher than 4.4.  The unit I purchased has android 7.1.1, I can fly the drone with it however there is no video display.
Also does the charging/com port on the left hand side of remote not function same as USB port on bottom of remote?
2020-4-15
UKMoose
Flight distance : 3657552 ft
Hi from UK, I have the Huawei MediaPad M3 8" It works brilliantly with dji go 4 and the latest litchi app, I also have the Huawei MediaPad T5 10" which works well with dji go 4, but litchi doesn't always opens first time.
2020-4-16
DJI Natalia
Hi wllmsnamy, you may refer to the mobile device compatibility list from DJI official web: https://www.dji.com/mavic/info#downloads
*Support for additional devices available as testing and development continues.
For stability and compatibility considering, you are recommended to try the device on the list above. Thanks.
2020-4-16
wllmsnamy
Does the tablet have to have GPS to work properly?
2020-4-16
wllmsnamy
DJI Natalia Posted at 4-16 03:28
[view_image]
So any device with Android 5.0 or later should work??? The two Nextbook tablets I purchased had android 7.1.1 and could not see the video.   What about the following, will it work?
Specification:
Brand : Victbing
Model : V10W
OS: Android Go 8.1
CPU: 1.5GHz Quad-core high-speed processing platform
GPU: Mali-720 MP2
Storage:
RAM : 1GB
ROM: 16GB
External Memory:Support SDHC
Display:
Screen type : IPS
Screen size : 10.1 inch
Screen Specification: Capacitive
Resolution : 1280*800
Network:
WIFI 802.11a/b/g/n
Bluetooth 4.0
MicroUSB
2020-4-16
Woe
Flight distance : 4129268 ft
wllmsnamy Posted at 4-16 05:06
You don't need wifi. It's recommended that you turn off wifi
2020-4-16
Woe
wllmsnamy Posted at 4-16 06:16
Specification:
When you connect your tablet make sure you are only using
one port. Meaning if your using the USB port make sure that
the side port cable is removed.If it's my choice I would go with
an Ipad. The iPad 2 works great with the original Mavic Pro and
should be fairly cheap.
2020-4-16
M2Wair
Flight distance : 1192231 ft
IPad mini 4 is great.
2020-4-16
DJI Natalia
Specification:
Hi wllmsnamy, to ensure the stability and the compatibility, you are recommended to try the mobile device on the compatibility list. At the same time, we'll forward your request to the related team, support for additional devices available as testing and development continue. We appreciate your kind understanding.
2020-4-17
CoreyB10
Flight distance : 1665023 ft
I have used the ipad Mini for all my DJI craft since I have been flying them. Currently on the iPad Mini V4 and they have always been flawless. A perfect combo of size and processing power. I'm not an Apple fanboy but this has proved to be my most reliable tablet to use in all locations and situations.
2020-4-17
Thudd
Flight distance : 1624787 ft
Yes, iPad mini 4
2020-4-17
