Hi Guys! Need help. I'm having an issue on SLOW SD CARD on Air unit. I'm using Sandisk Extreme PRO 64GB. I did a format in the airunit but still having the SD CARD SLOW every single flight. I'm running 700mw. I saw the recommended Sandisk is extreme (without pro). Should I upgrade the SD? I have this experience where expensive camera (Black Magic Cinema Camera 4K will only take recommenced SSD (Slow). And somehow the fast SSD it doesn't work well on the camera. I'm thinking it might be the same issue here?
