Wifi Range
1059 4 2014-11-18
aylottdaniel
Flight distance : 120295 ft
Hi All
just a quick one, if i fly out of range from the wifi extender with ground station will i still be able to see the hight & distence data on the app? also will i still be able to see where the phantom is on the flight path ?
thanks
2014-11-18
b.w.j
Denmark
When it go out of range, all data you mentored will be missing, and you cant see Phantom at all.
2014-11-18
aylottdaniel
I thought so thanks
2014-11-18
aylottdaniel
got one more question if my battery runs low when in the middle of a ground station mission will it stop the mission and trigger the RTH ?
2014-11-18
jmtw000
aylottdaniel@ho Posted at 2014-11-19 05:33
got one more question if my battery runs low when in the middle of a ground station mission will it  ...
If you have the "Low battery auto go home" setting enabled in the app I believe it will. However, you might want to test this before relying on it.
2014-11-19
