DJI Phantom 4 Battery Middle 2 Lights
4545 6 2020-4-22
paradeshi
Hi everyone!
Does anyone know what the flashing of the two middle lights mean? I put my battery on charge and the two middle lights along with the power light blinks for a second or two and go away. I left it charging for more than 5 hours but still nothing. Any ideas?
Middle 2 lights and the power button light up.
2020-4-22
JetSam
Flight distance : 3617244 ft
A Moderator will assist you soon , welcome paradeshi
2020-4-23
DJI Thor
Flight distance : 13602 ft
Hi there, the battery needs a firmware update. Please insert the battery to the drone and refresh the latest firmware via DJI Assistant 2.
2020-4-23
paradeshi
I did connect my drone to the software using a working battery and noticed that the firmware is up to date but when I plugin my non working battery nothing happens. How can I update the firmware when the battery doesn't 'boot up'?
2020-4-23
paradeshi
DJI Thor Posted at 4-23 01:41
Hi there, the battery needs a firmware update. Please insert the battery to the drone and refresh the latest firmware via DJI Assistant 2. https://www.youtube.com/watch?v=oQ_WEtnqI7c
Here's a video as well: https://1drv.ms/v/s!AgQ-gCIWyM_n0GyQx9vWd398LqFB?e=bMSobJ
2020-4-23
SswisS
Switzerland
paradeshi Posted at 2020-4-23 03:27
Did you ever find a solution to the problem? I have the same thing on 3 batteries. The Drone does not power on in this state so I cant check the firmware. Reset did not help either. Negative terminal to the reset button.
2024-9-29
paradeshi
SswisS Posted at 9-29 09:35
No luck had to discard the battery.
2024-9-30
