Motor Speed Error
1321 12 2020-4-29
johansenfoto
Flight distance : 1173379 ft
Norway
First day after the latest update, I got no errors. But today, the second time I also got Motor Speed Error.
Here is the video from today, I have also recorded the phonescreen.
Do I need to change the props, and is there anything else?
Yes I have updated all batteries too.
https://app.airdata.com/flight/7d54cca75b65cd7259c7afe85ddd3371/GENERALNotifications
2020-4-29
Deucalion
Flight distance : 103091 ft
Yes, change the props, Since you seemed to have made sure the FW update is complete.
2020-4-29
johansenfoto
Norway
Deucalion Posted at 4-29 09:27
I will do, but I just think it's strange that I had no problems last time
2020-4-29
Deucalion
johansenfoto Posted at 4-29 09:37
I agree. Let us know how it does afterward.
2020-4-29
Deucalion
2020-4-29
johansenfoto
Norway
Deucalion Posted at 4-29 10:09
I will do.
Going to try tomorrow.
2020-4-29
brainard.basuilgmail.com
Flight distance : 181985 ft
The issue only happened once when I updated the battery. I didn’t change the props and the issue didn’t come up again.
2020-4-29
Valpen
Flight distance : 13613556 ft
Norway
Received the same message after updating. Have checked the update again and all 3 battery.
Everything works fine, but still gets the message all the time.
2020-4-29
dronespilot
Flight distance : 1392995 ft
I got the same error. Luckily I have been reading about it before it popped up. I did firmware refresh as some of folks in another thread suggested and I will test it tomorrow and see if it fixes the error.
2020-4-29
adrianmendezGT
Flight distance : 78986 ft
Guatemala
Same problem for me. First flight after update and I got the message and the beep.
2020-4-29
johansenfoto
Norway
It work now, so thank you everyone for help.
I did change the 4 props in back and re-installed firmware with DJI Assistant 2.
I checked the props I took off, and one of them had a really small bend so it could be that one that gave the error.
2020-4-30
adrianmendezGT
Guatemala
johansenfoto Posted at 4-30 06:04
I only did a Refresh with Dji assistant 2, and work for me.
2020-4-30
jan.huigslootgmail.com
Flight distance : 72707 ft
Calibrate compass and imu. The problem here is gone
2020-5-2
