Hide DEM area in Terrain Awareness Mode
3097 21 2020-5-6
mailaerial-maps.com
Flight distance : 3543 ft
Hi All,
Since I cannot get my KML flight plan file to import when choosing Terrain Awareness (KML Exceeds DSM Range?), is there a way to hide the colored elevation area of the DEM in terrain awareness so that it just shows the satalite imagery to manually draw out my flight boundary?
Thank you,
Robert
2020-5-6
master.salah
Flight distance : 434449 ft
Kuwait
I hated the way that they implement DEM into their GSP app, I hope that the GSP app updated to has the integrated updated DEM like sensefly emotion and many other apps.
2020-5-6
patiam
Flight distance : 1118740 ft
yes this has been a complaint about DJI's implementation of flight awareness since day 1. half-baked as usual, with rare and infrequent fixes/improvements. they seem to be more interested in reinventing the wheel and making the inevitable mistakes than emulating tried and true (but open to improvement) models.
2020-5-6
jivago
Flight distance : 23671 ft
Hi, I don't know how you can hide the colored elevation but in that page there is a KML button. If you press it, you can select your area in KML format.
2020-5-6
CCAM
jivago Posted at 5-6 21:31
Hi Jivago,
Have you been able to get the KMZ to import in Terrain Awareness mode to work? I've tried every which way and always get an "KML Exceeds DSM Range" error?
2020-5-7
guillermomeiner
Argentina
you can hide DSM in plan - menu - general setting (last one  with 3 dots) - "Display Terrain Rendering Map" switch to OFF... you will still see satellite maps
2020-5-7
CCAM
guillermomeiner Posted at 5-7 16:35
Hi Guillermomeiner,
Great find! I can at least now draw my flight boundary manually and use the satellite imagery as reference in Terrain Awareness mode. Have you been able to get any KMZ to import in Terrain Awareness mode?
Thank you again!
Robert
2020-5-8
CCAM
CCAM Posted at 5-8 12:47
Hi Guillermomeiner,
I meant to say "any KML to import"
2020-5-8
CCAM
CCAM Posted at 5-8 12:48
Does DJI Support ever give input on these forums??? It would be nice if they could show us step by step procedures and programs used on how to get a KML to import in terrain awareness mode.
2020-5-8
guillermomeiner
Argentina
Yes i could!, just tap on KML and select kml. You have to import it previously.
In the screenshot appears a light red poligon
2020-5-8
guillermomeiner
Argentina
CCAM Posted at 5-8 13:04
hehe... sometimes... 2 or 3 times per year
2020-5-8
CCAM
guillermomeiner Posted at 5-8 14:26
Hi Guillermomeiner,
If I may ask what programs are you using to create your DEM and KML files? I have tried multiple times to get my KML to import into a Terrain Awareness project, however I always get an error "KML exceeds DEM Range", even though my DEM covers a much larger area than my KML.
2020-5-12
guillermomeiner
Argentina
Im using Global Mapper v21 for DEM and Google Earth for KML
In Global Mapper go to: File - Download Online Imagery/Topo/Terrain Maps - Select SRTM v3 (or what you prefer).
Before that i usually open a kml (polygon) of the city or town i want the dem, so i can clip the dem to that region
Once downloaded Right Click in the layer, Layer, Export, Geotiff. I think you can leave all default but be sure to check "Generate TFW"
Then copy both files (TIFF and TFW) to a new folder (DJI/DSM/TOWN1) in the root directory of microsd card
BE SURE in Global Mapper units are Geographic (LAT/LONG): Tools - Configure - Projection - Select Geographic (Lat/Long), Datum (wgs84) - Planar Units (Arc Degrees)
Let me know if you cant make it work and maybe we can talk about it via Wasap or zoom
good luck
2020-5-12
CCAM
guillermomeiner Posted at 5-12 12:40
Thank you for this. I will give it a try. I was using United States Elevation Data (NED) 10m Res, maybe that was the problem? I'll let you know if it works for me.
Thanks again!
2020-5-12
CCAM
CCAM Posted at 5-12 13:21
Thanks again!
Still no luck. I tried using the exact same method you mentioned and I am still getting the "KML exceeds DSM range. Select new KML" error as shown on the attached image. Are you saving the KML out of Google Earth and special way?
[img]202005/13/093949ps1hkg46sups1qdt.jpg[/img
Thank you,
Robert Lafica]
2020-5-13
CCAM
CCAM Posted at 5-13 09:40
2020-5-13
CCAM
As you can see, limits are clearly within DEM range.
2020-5-13
guillermomeiner
Argentina
hmm... looks like the problems is the kml. I usually do this:
open google earth, add polygon (i have in spanish i dont know if this is the translation), click on boundaries (be sure to be inside the DEM), accept,  then in layers right click on the polygon layer - save as - kml
save it on microsd under DJI/KML folder and import it
and that's all... it should work
please let me know
2020-5-13
CCAM
guillermomeiner Posted at 5-13 15:14
Strange. That is exactly what I am doing, but no luck. When you create your boundary, in the properties tab, do you have the Altitude set to "clamped to ground"?
Thank you,
Robert
2020-5-13
CCAM
CCAM Posted at 5-13 15:26
Thank you,
I have sent my DSM and KLM files to the DJI support team. Hopefully they can figure out what the issue is.
Thank you,
Robert
2020-5-13
guillermomeiner
Argentina
Thank you,
yes... no altitud
2020-5-13
guillermomeiner
Argentina
CCAM Posted at 5-13 15:32
Thank you,
please send it to me.... gmeinero@gmail.com
2020-5-13
