Waypoint flight planning
660 1 2020-5-6
fans1a3151c5
Flight distance : 434449 ft
Kuwait
Hello everyone,
It's not good to be able to use Mavic pro with Litchi to create a waypoint flight easily and set all desired actions, and in the same time, I have Phantom 4 RTK that I need to use it for the same mission to make use of RTK Station to make the photos and videos in the same frame every month.
The Waypoint flight in DJI GSP is required to set the base station and fly the drone to set points, why can't I do a pre-planning for that mission like 10$ app do (Litchi)?
I found the solution using DJI Terra, but to be honest, using RC with USB attached to Laptop for Waypoint mission is a kind of headache for sure. I'm not using a fixed-wing drone, hey, it's multi-rotor!
I hope DJI updates Waypoint mission to be able to pre-plan and modify anything after fly, as the modification is much easier than setting points and actions while the drone is hovering!
Anyone try to use Waypoint flight with success?
I really hated DJI Support...
Ahmed Metwally
2020-5-6
master.salah
Kuwait
Also, I have a question.
Do I need an active license to use DJI Terra to fly drones only?
2020-5-6
