JJB*
Flight distance : 12225059 ft
Hi,
Oops, few drone flyers did loose their drone this way.....(above water).
If a DJI drone flys low altitude (hover or any moving direction), about 0.5 meter above the ground AND user is applying for short moment 100% down stick ; drone will enter an autolanding mode. Its the same as a normal landing, hover at this height and 100 down stick > autolanding.
Sometimes it happens at between 70 - 99 % down stick, try it yourself during normal landing.
The only way to stop this is to pull up, as you did. But if you are not aware of this than....AND if VPS height is misreading height (above clouds, fog etc) or simple an error ; than also into an autolanding.
See my chart.
cheers
JJB
