Speedbird1
Flight distance : 218337 ft
Geebax Posted at 5-10 14:35
Please understand that the feed back to the iPhone is simply intended to give you a view of where you are flying or allow you to frame shots or video. It is not intended to be a flawless feed, and it never will be. This is why the recording method is contained in the aircraft, so it will be a continuous feed, while your FPV feed may break up from time to time due to interference or atmospheric disturbances. From your video, it appears you are inside, in which case there will be multiple devices in the household that use the same frequency band that the drone uses, in particular the home WiFi system.
Thank you for your reply however I am aware that the actual imagery goes direct to the SD Card hence me saying that the quality is great. The demonstration was done inside but only to show what happens all the time even when outside. Oh, By the Way, it has never done it previously, in the couple of years i've had it.
One of the problems with the screen doing what it does is, i am not able to see what speed I am turning the drone during footage until i check it out later, or if i'm getting too close to something whilst filming.
Any more ideas please? |
