Phantom 4 Pro V2.0 - How to downgrade the firmware?
4619 10 2020-5-11
Akbuk
Czechia
How can I downgrade my Phantom 4 Pro V2.0 with the last firmware version 01.00.50.00 to an older version? DJI Assistant and DJI GO App do not offer this option.
2020-5-11
JetSam
Flight distance : 3462946 ft
better DJI Assistant
2020-5-11
JetSam
    DJI Assistant 2 for Phantom https://www.dji.com/es/downloads ... t-dji-2-for-phantom
2020-5-11
Akbuk
Czechia
DJI Assistant and DJI GO App do not offer this option. Im afraid, P4P V2 with latest firmware is not possible to downgrade.  P4P V1 is possible, but V2 not.
2020-5-11
DJI Thor
Flight distance : 13602 ft
Hi, for Phantom 4 Pro V2.0, once the firmware is updated, it cannot revert to a previous version. May I know if you encounter any trouble with the drone?
2020-5-11
Akbuk
Czechia
Hi. The previous firmware version was more stable. Now I have stability problem during hoover and drone doesnot fly straight. Before no problems...
2020-5-11
rwynant V1
Flight distance : 4842277 ft
Akbuk Posted at 5-11 06:18
Following an update,  Calibrating your IMU as well as Compass would be a normal process.
This may help with your stability and straight line flying.......
Randy
2020-5-11
Akbuk
Czechia
I updated the firmware several times. I calibrated  IMU, compass and sensors after the update.
2020-5-11
Jebtir
Flight distance : 1126516 ft
Brazil
I need to downgrade too. Any suggestions?I need to downgrade too. Any suggestions?
2020-5-22
Germ0o
I need to DOWNGRADE !!! My drone worked fine before this UPDATE. NOW  the IMU will not calibrate! error -50.....please help!! the new firmware BRICKED my P4P, I have the Version 1...
2021-2-20
djiuser_4ThTGeobWVYh
DJI Thor Posted at 2020-5-11 05:41
I am having a problem with the camera pointing straight down and the most common way I’ve seen to fix it is to downgrade the software but there is no version to downgrade to
2023-1-5
