JJB*
Flight distance : 12401030 ft
Hi bablefish,
Had a look at your flight and i am puzzled.
At the end of your flight, with no RC input your MM was stable hovering at 223 meters away, pitch and roll angles low ; so not to much wind to fight against.
Earlier in flight your RTH performed OKE, speed towards home between 6 and 7 m/s with pitch down angle of approx 27 degrees. At 2m38 distance to HP 197 meters, at 2m55 you cancelled RTH at 103 meters from home. So all looks normal to me.
Why after the disconnect your MM did not fly home?? i have no idea.
Only at the end few times more this warning : " Strong wind warning. Aircraft unable to Return to Home automatically. Lower altitude immediately and Return to Home manually"
So mayby (guess the only logical reason for not returning to home) is more wind at the end at that distance out if 225 meters, but as said before 'hovering with low pitch/roll angels' are telling less wind. So i am puzzled.
cheers
JJB
