Propeller
647 12 2020-5-20
ken.fry1btinternet.com
Flight distance : 5778 ft
New Phantom delivered today try to assemble the Propellers,  push down twist to lock But do not twist to the lock position any ideas, I'm afraid to use force in case of damage but they will not twist into the lock position black or white,  phantom 4 pro+ V2.0
2020-5-20
Labroides
Flight distance : 9991457 ft
If you have the right props on the right motors, there's not much you can do wrong.
2020-5-20
Labroides Posted at 5-20 05:33
Thanks for your quick response,
I have tried in all shapes and forms ,Silver to silver black to black with no success I couldn’t push down and twist any harder,  as I said this is the fourth phantom I have had, any ideas These are the new shaped propellers  that came with the unit, All brand-new out-of-the-box today.
Ken
2020-5-20
Anokadrone
Flight distance : 58327 ft
One thing you could try is if you have an older Phantom 4 prop.  you could see if that installs.   If yes, then there is something different with the new props.  If no, then something is up with the motor hubs.
2020-5-20
Anokadrone Posted at 5-20 06:15
Yes you are right, the old phantom 4 pro +Propeller fit on no problem,
The problem is now how to sort it out because obviously I can't use the OLD Propellers because of the warranty factor, I wonder what the difference is, if anybody else has come across this problem it Would be nice to know I if they resolved it through DJI
2020-5-20
Labroides
ken.fry1btinternet.com Posted at 5-20 06:40
The original Phantom 4 (not pro) had a different prop locking mechanism.
Perhaps you have the wrong props?
Here's what the props and hubs look like for a P4 pro:
2020-5-20
KEJ
Also,  like Labroides has posted a picture, I would suggest doing the same and that's probably the quickest way to get a definitive answer.
2020-5-21
DJI Natalia
Hi there,could you please provide a short video or some pics about this issue for better assistance?
2020-5-21
Mr. Strat
Flight distance : 4542854 ft
I had the same problem when mine was new. Had to use a rubber strap wrench to hold the motors still. It's loosened up with use.
2020-5-21
rwynant V1
Flight distance : 4842277 ft
Make sure ALL the plastic wrap around the props hub is cleared and NOT in the way.....
Randy
2020-5-21
Mr. Strat Posted at 5-21 09:46
Yes thanks for the tip but not exactly a quick release mechanism is it, I think DJI wants to sort the fault out.
Regards,
Ken
2020-5-21
rwynant V1 Posted at 5-21 19:50
Randy
Yes all plastic was removed, still no joy it looks like people are in this fault with this particular model, I think
dji Will have to sort this out which in all fairness this is the first Time I have had a problem with any of the products I bought off them.
Regards,
Ken
2020-5-21
rwynant V1
ken.fry1btinternet.com Posted at 5-21 22:44
Regards,
I also have a P4Pro V2....standard RC
Bought in January right when they were re-released.
The left rear prop should have a silver ring, and the right rear prop should have a black ring.
Make sure the top of the left rear attachment on the motor is white, and the right rear has black dots......If that's not the case then they may have assembled incorrectly......can you upload a picture for your mounts?
Randy
2020-5-22
