MA2 Processor chip overheated Code: 30136 / 30185
6182 23 2020-5-20
fans4af89851
Flight distance : 16588 ft
Anyone else getting an overheated error? The brand new drone, one of my first flights and almost lost the drone. I thought it was due to trying the new 4K 60fps but it just did it again at 4K 30fps tracking me. This sucks.
Once it overheats, I lose control of the drone as the screen feezes. The drone wants to return home. The last time I was under the trees which would have caused a crash. Luckily the only control that works on the controller is the elevation and I got it by pulling it down, grabbing it in the air, and flip it to shut down. It did the same thing the second time and I got it to do it while not in flight, which is how I finally got to see the code.
Chatting with DJI now. /
Update: Not sure if its Covid 19 or what... but customer service is very slow now. Im asking for a refund...
2020-5-20
beaulebens
Flight distance : 27182 ft
There are a couple of other threads on here about the same thing. I’m seeing it as well. Just did a test flight with a different battery and didn’t get it, so am going to try all batteries in my set to see if it’s maybe related, but is really annoying.
2020-5-20
gutiejorJAG
beaulebens Posted at 5-20 19:15
That’s a good idea. I did have a flight where I had zero problems. I will do that the same tomorrow. Thank you!
2020-5-20
gutiejorJAG
DJI just wants me to send it in for repair.. this sucks. Person in chat didn’t seem to know anything about it and even if I should return the drone alone or with everything.
2020-5-20
DJI Gamora
Hi, fans4af89851. We apologize again for the inconvenience. Please power on the aircraft and let it sit idle for a while, then check whether the fan spins. If the fan rotates, please upload the flight records and flight controller log. If it does not rotate, please send the product back for diagnosis.
Here's the link to initiate an Online Repair Request. https://repair.dji.com/repair/index?site=brandsite&from=nav
2020-5-21
gutiejorJAG
DJI Gamora Posted at 5-21 01:30
The inner fan turns on just fine, almost immediately after turning on the aircraft. I have the flight records, it did it 2  out of the 7 times I flew it. should I upload all 7 files or just the 2 that failed? and to where?
2020-5-21
gutiejorJAG
@DJI Gamora Like I said, fan kicks in just fine.
Below are the two flights where it overheated and I almost lost the drone. Looks like it gave code 30185. In panic I did not catch the code.
I got it to overheat twice again by just recording while not in flight, it stop recording and asked to be restarted. It gives me code 30136. I took a screen shot, attached.
https://app.airdata.com/share/ZloHWi
https://app.airdata.com/share/JNLUaU
2020-5-21
djiuser_bacGRlQgyAL5
I am also disappointed that the same problem occurred. Do I have to send this for repair?
2020-5-24
djiuser_VRAB3CnsU8b7
I've gotten the same message on every flight except one for two day.  The exception was after the ambient temperature had dropped to about 70F.  On the flights where the processor overheated it was in the 80's.  The flight times ranged from 15 minutes to as short as 5 minutes before it overheated.   I can hear the fan and feel air being exhausted.  There don't seem to be any obstructions to airflow.
2020-5-24
gutiejorJAG
djiuser_bacGRlQgyAL5 Posted at 5-24 13:02
Unfortunately they weren’t much help. They wanted me to send it for repair which I think it’s the worst thing a company can offer after a customer paid $1000!!! It would take a month to get back to flying.
I asked for a refund and ordered a second drone while they get the refund processed.
2020-5-24
gutiejorJAG
djiuser_VRAB3CnsU8b7 Posted at 5-24 13:12
Same here. Fan kicks in. Although, I can’t figure out if the grill behind the camera is suppose to be a fake one like mine is.
2020-5-24
bwaler
Flight distance : 3314541 ft
My guess would be the thermal paste on the processors wasn't applied well or there wasn't enough of it. See video at the 2 minute mark.
2020-5-25
gutiejorJAG
bwaler Posted at 5-25 04:49
https://youtu.be/9Uy9QNidi1U?t=128
Wow that video was a great watch!
2020-5-25
Natemare13
Same issue here. fan is on. It happens when recording video of any frame rate or resolution. I can’t get more than 1min flight before it returns to home and I can’t cancel it or manually land it. Ambient temp outside is 70 degrees F and the fans sound just fine/normal. What is going on DJI??!!
2020-5-30
DJI Gamora
gutiejorJAG Posted at 5-21 07:56
Sorry for the trouble, please submit an online repair request using the link that I had provided above. Once you submitted an online repair request, please have the case number and send an email to support@dji.com with case number and provide us the uploaded flight logs. Thank you for your understanding and support.
2020-5-30
Moni Johnson
Flight distance : 1375846 ft
I suppose I'll wait for the MP3 (the quad, not the music file format) then. The Texas heat here might be a major issue for the MA2 if it's overhearing even at 70 degrees F. It easily gets hotter than 100 degrees here for several weeks a year.
2020-5-30
Natemare13
What would you do if this is the case?  Do you know the type of paste they used or could one use regular CPU thermal paste?
2020-5-31
bwaler
Natemare13 Posted at 5-31 04:24
I'm no expert on the problem but I would assume CPU thermal paste would be sufficient.
2020-6-20
David Martin Graff
Flight distance : 106566408 ft
I have had that happen to me flying the Spark in 105 degree temperature.
2020-6-20
Lampengeist
Flight distance : 45085 ft
here Natemare13 has fixed the overheating problem. I don't recommend to do that, it's only for information so you can see where the problem comes from:https://forum.dji.com/forum.php?mod=viewthread&tid=217010
Also with my MA2 the fan starts round about two minutes after switching it on. So if it starts immediately it seems that there is some thermal paste missing or bad attached.
2020-6-20
fans8506bccd
Man it sucks these new drones are plagued with such crap issues
I am waiting for my brand new replacement and I hope mine doenst have this
First time it was the gimbal motor overload.
2020-6-21
djiuser_5p0bEWsm7cAK
I have an overheating issue with mine too. Fortunately it will not let me fly.
2021-1-4
COOLDR73
Good Afternoon,  I have a DJI Mavic Mini, error code 30136 overheating issue, any ideas on a quick fix please, I can see a error code listing but not for 30136. any info would be appreciated.
mini turns on and does self test and then turns off?
thanks in advance.
2021-3-14
djiuser_uGHbZWQkVRPb
Flight distance : 2312231 ft
Chile
Que puedo hacer dji? Tengo el mismo problema, tengo secuestrado mi drone en un servicio técnico aprobado por dji, hace dos meses que lo tengo ahí y no hay ni una solución! Ya no puedo seguir esperando, que puedo hacer?
2021-4-12
