XT2 Settings for Thermal Mapping
1368 1 2020-5-25
nodloh
Flight distance : 386398 ft
HI All,
I have played around with our XT2 for thermal photogrammetry but still trying to dial in the best settings.
We're using a 25mm XT2 and generally map concrete structures.
At the moment I use, White Hot Palette and played around a bit with the scene mode.
The main thing I'd like to achieve is to prevent the shift in temperature gradient between images.
I have noticed previously that if a hot/cold object comes into from it will skew the whole colour palette to accomodate.
This can lead to some issues with tie point matching in photogrammetry processing.
Can anyone recommend a way to lock the temperature scale so a given temperature is always the same colour?
Any feedback would be much appreciated.
Thanks,
nodloh
2020-5-25
Libitron
Flight distance : 130853 ft
Exact same problem here with XTr 640. With 85% overlap, different temps on same object in every picture. There MUST be some calibration happening to cause this.
2022-8-2
