Short Range signal
632 3 2020-5-26
djiuser_eXcl90PVMbsb
The signal becomes low within low range.  I'm new to FPV.  It is set to 700mw.  All the antennas are properly connected.  Is it normal?  Here is the video. It is Iflight Titan DC5
2020-5-26
Giammi
Flight distance : 847795 ft
Two things to mention, not in LOS (you should rise your altitude when flying far from yourself) and close to those antennas (?). Not really a good scenario.
2020-5-27
Giammi Posted at 5-27 02:01
I was facing all the time to the drone.  The signal dropped to 1 just 1 block away.  The drone was mostly LOS.  If you check the path when I was returning due to signal became very low I was LOS. I was right next to the black car.
2020-5-27
USS ENTERPRISE
Flight distance : 2063642 ft
South Korea
There is giant antennas near you
2020-5-27
