MAVIC mini video problem.
862 2 2020-5-29
graham davie
Flight distance : 111247 ft
Hi all, had the Mini since day one, no problem’s until a couple of days ago.
When in video mode, I cannot get a video to last more than 12 seconds. It will cut out and I have to go back into video mode to resume filming.
12 seconds is the longest I have managed, it often cuts out after 5 or 6 seconds.
As I say this has only started to happen in the last couple of days.
All software/firmware is up dated, so I’m at a complete loss as to why it has suddenly become a problem.
Any ideas would be much appreciated.
Many thanks, graham.
2020-5-29
Hi graham, we are sorry to read the problem with Mavic Mini, what Micro SD Card are you using? UHS-I Speed Class 3 or above is required. A list of recommended microSD cards can be found below. Did you have a try with another Micro SD Card?
16 GB: SanDisk Extreme, Lexar 633x
32 GB: Samsung Pro Endurance, Samsung Evo Plus, SanDisk Industrial, Sandisk Extreme V30 A1, SanDisk Extreme V30 A2, SanDisk Extreme Pro V30 A1, SanDisk Extreme Pro V30 A2, Lexar 633x, Lexar 667x
64 GB: Samsung Pro Endurance, Samsung Evo Plus, SanDisk Extreme V30 A1, SanDisk Extreme V30 A2, Lexar 633x, Lexar 667x, Lexar 1000x, Lexar High Endurance, Toshiba EXCERIA M303 V30 A1, Netac Pro V30 A1
128 GB: Samsung Pro Plus, Samsung Evo Plus, SanDisk Extreme V30 A1, SanDisk Extreme V30 A2, SanDisk Extreme Plus V30 A1, SanDisk Extreme Plus V30 A2, Lexar 633x, Lexar 667x, Lexar 1000x, Lexar High Endurance, Toshiba EXCERIA M303 V30 A1, Netac Pro V30 A1
256 GB: SanDisk Extreme V30 A1, SanDisk Extreme V30 A2
2020-5-29
fabien.cases
Flight distance : 43891 ft
Hi Graham, I have exactly the same issue on my Mavic Mini with a sandisk U3 V30 A2 128 GB. Did you manage to fix your problem? Cheers, Fabien
2020-7-13
