cutis
Flight distance : 1695351 ft
DJI Mindy Posted at 5-31 22:19
We've verified with our engineers that there is only one generation of Mavic Air, the newly-shipped drone removed two screws on the top cover, this is the only difference with the older drone. We hope this helps you with your decision.
Thank you Dji Mindy
Then I embark into perfecting grapevine's rma'd mavic air generation2 revision which abandoned the top ornamental cover two each fastening screws.
Is there a way for you to check grapevine's logs in determining core board evaluation outcome for serial number 0K13G4Q00DK041 ?
The grapevine returned this drone denying any repair because they claimed crash yet grapevine stamped it QAQC okay returning it. It flies and obeys the rc. But the portside magnets strength is immensely stronger & more powerful against the starboard's permanent motor magnets and this ruins optimal efficiency propulsion wise. Further, when I took off this ornament cover, beneathe lay chloride contaminant factory fingerprinting stains, chemical reaction, that effectively corrodes delicate metallurgical surfaces which contacted the factory laborers perspiration finger tips. Inside my pc computer, it is not corrosive by perspiration salts because I assure cleanliness. This is why I am asking whether grapevine documented any info whether this core board has any issues with it.
This mavic air is not complicated and I can reassemble if I disassemble, easily. Now I know grapevine returns less than what it received, returning the corroded core board having fingerprints over it causing corrode by human staining of salts in handling. That is a standard practice no-no. |
