AlansDronePics
Flight distance : 823163 ft
Guernsey
Commenting on the battery, first. LiPo batteries that self discharge by as much as you suggest indicates the batteries are not in prime condition. To put this in some sort of context, I remember my laptop batteries behaved like yours are doing after a lot of use and were known to be close to death. A full charge and immediate use did run the laptop (s, there were several over the years) at about 70 full capacity. My current laptop holds full charge for at least a month. I recently moved house and discovered some old LiPo cells I bought way back in 2005. I never used them, but out of curiosity, I put them on charge and found they showed fully charged after 15 minutes. They were fitted into a torch, to see if they still had any capacity. The lasted longer under test than the well used cells from the torch. Regarding range. You never mentioned at what charge level remained when you decided the batteries were used up. You mentioned 15 minutes use. Was this with 30% charge showing (the usual DJI default ) or 10% or zero? My 2016 Phantom 3 pro has always shown about 17 to 18 minutes flight when the 30% warning to land goes off. Those batteries are well used and are the original. 4 that I bought with the drone. You also didn't mention if the range you claimed in the built up area was achieved with nothing like buildings or trees, for example, in between. Think of it this way, If you had binoculars, could you still see the drone? Anything in the way will reduce signal strength and the wise advice from others about WiFi interference is more relevant than ever. |
