OSDK4.0 failed to get the main camera video stream decoding
2090 5 2020-6-8
djiuser_JzstkYN171Op
China
I want to get the image stream of the main pan/tilt camera of the drone, using the DJI M300 RTK, the pan/tilt camera is Zenth H20, the OSDK-ROS version number is 4.0, the development platform is MANIFOLD 2-G, Ubuntu16.04 system, The ROS version is kinetic. Through the roslaunch dji_osdk_ros dji_vehicle_node.launch command, run the protagonist point of OSDK ROS 4.0, and then start the advanced sensing function advanced_sensing_node, generate a .h264 file, you can use streameye to open the playback, but view the file information, you can not get the P frame , B frame, I frame of the video stream. How can I decode and play?
2020-6-8
xiao long
This phenomenon is not normal, it is recommended to send out the H264 video stream file to have a look.
2020-6-10
China
xiao long Posted at 6-10 06:00
Hello, sorry, H264 video file is too large to upload. Can you send your email?
2020-6-10
xiao long
This image is an official DJI analysis of the H264 stream. The H20 camera should be able to get P frames.
It is recommended to use Elecard StreamEye Tools or H264Visa for analysis.
2020-6-11
China
xiao long Posted at 6-11 04:36
[view_image]
Excuse me, if all P frames, how to decode and display?
2020-6-11
xiao long
The H264 stream has only P frames, indicating that it is GDR encoded and needs to be decoded using the GDR encoding format, such as you can using  JM decoder.
2020-6-12
