M300 RTK NOT connecting to RTK station
9186 29 2020-6-9
DFL-LM
Flight distance : 860 ft
United Arab Emirates
Hi,
I've recently purchased the new DJI M300 RTK. It flies perfectly fine. However, when I try connecting it to the D-RTK station, I get the message "No D-RTK 2 Mobile Stations found". The station is on, and is in "Operationg Mode 5 Mobile Base Station (Broadcast Mode, M300 RTK)".
All lights on the station are green and the Operation Mode light flashes 5 times indicating it's in Mode 5. I've followed all the instruction as per the D-RTK manual
Any idea what the issue could be? All firmwares are up to date.
2020-6-9
Mafia16
Flight distance : 26490948 ft
Dominican Republic
please update your remote you are in the old firmware
2020-6-10
speedbird747
Flight distance : 158983 ft
Not only the remote but also the M300 firmware, charging station, batteries and payloads! If using an H20 series you can only upgrade that via the memory card with firmware in root directory.
2020-6-10
DFL_SIMBA
Thanks everyone. It's all solved. The Controller + Drone firmware update.
The controller was not detecting the new update form the cloud nor when I connect it to my Assistant 2 for Mac. I was only able to update it through Assistant 2 for windows for some weird reason.
2020-6-10
speedbird747
DFL_SIMBA Posted at 6-10 21:20
Same for me DJI Assistant 2 on my iMac wouldn't connect to the M300 so I used a Windows laptop instead.
2020-6-11
We are glad to know the issue has been solved with the help of Mafia16 and speedbird747, please keep us update if there is any further problem.
2020-6-12
djiuser_LuDIehOtN335
I have exactly the same issue. It connects fine with a slow blinking red light (indoors) but as soon as more satellites are picked up, it disconnects. I've checked the firmware several times, but will try again now. I'm in touch with DJI support about this as COPTRZ weren't able to diagnose this any further either.
2020-9-12
What should the latest controller software be? I've just refreshed all software to: Enterprise Controller V01.00.0213 using Windows. Pilot app is on V1.09.OR. The D-RTK 2 is on V03.00.0013. M300 RTK is on V01.00.0211. Batteries all on the latest too. Just tried it again, and still have the same issue. I've tried different modes, different start-up sequences, different locations and even two D-RTK 2 for Matrice Mobile Stations. Whatever I try, I get the same results. Could it be the RTK antennas on the aircraft itself?
2020-9-12
micerv
Hello, I have problems with the D-SDK2 antenna mode change. I followed the steps in the instructions, but I can only switch between modes 1 and 2 and back. I would need mode 5, for connection with Matrice 300. Thanks
2020-9-19
Craig_Tas
Flight distance : 2998255 ft
Just to let others know, my RTK ground station fresh out of the box would blink twice on the mode light but if you try to change the mode the device would reboot, ended up being firmware that needed to be updated via DJI Assistant 2 for Matrice Series on my PC (Windows). Once that was done it worked as instructed.
2020-9-20
djiuser_twaYo5skP8cU
Denmark
I do have the same issue - any solution, all upgraded to newest firmware using Assistant 2 for Matrice 13-10-2020 ?
2020-10-13
HV_Sparks
Flight distance : 732267 ft
micerv Posted at 9-19 06:35
I had the same issue - it was resolved by activating the RTK ground station in the DJI Assistant2 for Matrice on my laptop. A pop up will show stating requires activation.
2020-10-14
HV_Sparks
Unfortunately I too am having the same issue that the RTK will not show on the list within the Pilot app and it will only connect indoors.
2020-10-14
HV_Sparks
I have been in touch with DJI directly and this issue is a high priority and being dealt with accordingly.  Once I am told any further news I shall update with a new post below.  I am expecting a FW revision to be issued.
2020-10-15
micerv
I also continue to have connection problems between the Matrice 300 and the D-RTK2 mobile station. It happens to me either to search for the station and not find anything or I receive the message (RTK CONNECTED. RTK DATA CONVERTING) and in the end however, the station does not connect
2020-10-15
HV_Sparks
I have received a fix from DJI - it is in the form of a pre-release FW for the RTK2 (v03.00.0015).  I am unable to share the FW as I had to login into Assistant2 for Matrice using a specific DJI account, not my own.
I can confirm this has completely fixed my RTK2 connection issues and strongly advise you contact DJI to obtain the necessary instructions to update your RTK2.  I presume this will become a public FW release in the near future.  The aircraft & controllers don't require an update.
2020-10-20
micerv
Thank you for answering me and for the good news you gave me. My firmware version is V03.00.0013. Can you tell me how you contacted DJI and got the new version of the firmware. Thank you
2020-10-24
HV_Sparks
micerv Posted at 10-24 01:43
Hi,
I spoke with my supplier and they spoke to DJI.  The FW version required is V03.00.0015 and is not a public release as they're still testing it for general release.  I am waiting to hear back from DJI if I am allowed to share the information with other users.
2020-10-26
micerv
Ok, thanks
2020-10-26
Yes Yes Rudi
Flight distance : 1362067 ft
Austria
Hello
I have the same Problem
ng Rudi
2020-11-17
micerv
We are waiting for the new firmware
2020-11-19
nikolaospaschalisgmail.com
Flight distance : 3093517 ft
Greece
Hello guys
I have a similar issue.
I did the update for Matrice 300 but still get disconnection.
My firmware thought looks strange
2020-11-24
Greece
Update
Same with me
I contacted DJI and I got a new login in the assistant  -tried beta and worked fine.
My question is that I can not see anywhere a 3.0.0.xx version ...
Why is that?
2020-11-26
micerv
Hi, please tell me at what address did you contact support? I would also like to try the beta, right now I can't work
2020-11-26
fans566d4ddd
Flight distance : 18275925 ft
HV_Sparks Posted at 10-26 02:44
Hi,
Hi HV_Sparks
Can you share the FW information?
Thanks in advance
2020-11-27
Chinthana_95
Sri Lanka
For that, you need to update the firmware of D-RTK 2. I had the same issue once I updated the firmware of  D-RTK 2 issue was sorted.
2020-12-4
Chinthana_95
Sri Lanka
My M300 RTK and smart controller shows the signal strength of RTK like this.
Does anyone have this issue?
2020-12-4
KK_Pilot
Latvia
Hi, I'm having the same issue.
Which FW version should fix this?
I don't have access to the station right now, but ~week ago DJI Assitant still showed that my V03.00.0013 is the latest version.
2020-12-11
micerv
Hi. It seems that DJI has created a new firmware that solves the problems but it has not yet been released. If you read any of the above messages, a user received an unofficial firmware from the DJI but was asked not to share it
2020-12-14
Bule Bule
Flight distance : 2581713 ft
Mexico
Hello, on Sunday the RTK gave us problems, it connected to the control, but not to the M300, we flew without RTK.
At another point, the same day, we had no problems.
The M300 is up to date
What could it be?
2021-9-28
