Dji Lightbridge gets only up to 8 channels
1927 3 2014-11-19
asi
I installed my lightbridge on the S900 using a futabe 14sg remote .
All the channel are working fine but only up to the 8th channel.
Any Chanel after the 8th channel is not working .
I conceted the F2-F4 prots of the A2 to the Shut ,Mode , Aux 1 over the zenmuse gcu .
When i use the futaba dirctlly bind over the A2 all the rest of channel are working .
Please advice
2014-11-19
Blade_Strike
Flight distance : 872694 ft
You need to turn on 12ch mode in the trainer menu, page 4 of the sub menu.
2014-11-19
soeren.renz.ema
Dear all,
I've got the following problem: Within the lightbridge assistent, all channels are driven correctly (1 - 12) but when I try to map these channels to there accociated function, channels 9 - 12 are not working within the A2 assistent. There is no reaction on any of the inputs. I'm really not sure why this happens so maybe someone from u guys can give me the right hint to get it working. The Trainer function within my T14SG is set to 12Chg, everything else wasn't changed and is left to Standard.
2015-1-26
DJI-Jackson
Flight distance : 51243 ft
China
soeren.renz.ema Posted at 2015-1-26 23:49
Dear all,
I've got the following problem: Within the lightbridge assistent, all channels are driven ...
Hi,buddy.Please note:
1, Set FASST MULT as the protocal of futaba ;
2, Turn on 12ch mode in futaba ;
3, Set 9ch~12ch as "AUXLL IARY series".
2015-1-26
